boost controller
Old Jul 30, 2008 | 03:28 PM
needsagst98's Avatar
Default boost controller
i have a 98 gst and my mbc seems to not be working. my car wont go past 13 to 14 psi. i have a turbo xs mbc with fine tune. it was on the car when i got it. both of the end werent sip tide so i sip tide them so nothing could leak out or anything. i looked up the instrustions to it and how far do u have to more the screw to get more boost?. i went 3 or 4 whole turns in and nothing? any ideas
Old Jul 30, 2008 | 07:40 PM
Default RE: boost controller
are you sure that it is installed correctly.
Old Jul 30, 2008 | 07:54 PM
im pretty sure. is there a stock mbc?
Old Jul 30, 2008 | 08:07 PM
or ebc? casue it is tapped into a diff line going to something electric. should this be unplugged all together and only run it throught the one line?
Old Jul 30, 2008 | 08:30 PM
dsm1990gsx's Avatar
Can you post pics?
Old Jul 30, 2008 | 10:56 PM
ok i found it all out reseasrching it. i just elimited the stock line. and went from turbo pressure line to mbc then into the wastegate. i usually vaccum at 20 and now im vaccuming at 19. would this be a small leak in one of those lines?
Old Jul 31, 2008 | 12:16 AM
Fully close the valve and see what that does (clockwise)
That vacume is normal by the way.
Old Jul 31, 2008 | 12:20 AM
silvercoupe97's Avatar
It's a bleeder valve, it's normal. But it would seem that you may have the **** too loose. Also check to be sure that you don't have old and crusty vacuum lines for leaks.
Old Jul 31, 2008 | 09:40 AM
clockwise pulls the screw all the way out?
Old Jul 31, 2008 | 10:16 AM
It does? Well then the other way.
When the f does turning something clockwise screw it out...
