boost controller????help!!!
According to the pic I posted. My setup is almost there. But there is one little thing that is different. If looking at the pic... Off the MBC there is a hose running straight to the Wastegate. But on mine I have a hose running off the MBC to a t-fitting. And on that hose that has the t-fitting it runs from the wastegate to BCS (wastegate solenoid). So my question is... do I unplug the BCS (wastegate solenoid) side and connect my MBC straight to the Wastegate? As shown in the pic.
hey i had the same problem i have a turbonetics mbc. to hook up mine you hook one hose to the wastegate itself and the other one on the tee fitting where the wastegate did. so in other words that little hose that went to the wastegate and the tee fitting in trash. you just plug your mbc between those two points no wires get un plugged or any other hoses. you should have the same set up but i dont think it matters. try this i almost positve it will work
