boost controller????help!!!
Old Jul 11, 2006 | 01:55 PM
Default RE: boost controller????help!!!
Umm you put caps where the original hoses went
Old Jul 11, 2006 | 02:01 PM
agallardo's Avatar
According to the pic I posted. My setup is almost there. But there is one little thing that is different. If looking at the pic... Off the MBC there is a hose running straight to the Wastegate. But on mine I have a hose running off the MBC to a t-fitting. And on that hose that has the t-fitting it runs from the wastegate to BCS (wastegate solenoid). So my question is... do I unplug the BCS (wastegate solenoid) side and connect my MBC straight to the Wastegate? As shown in the pic.
Old Jul 11, 2006 | 02:28 PM
yes then you remove the bcs or just plug up the hole there
Old Jul 11, 2006 | 02:45 PM
agallardo's Avatar
Thanks. Is that all I have to do?
I have already removed the BCS. So do I have to cover it up? or leave it open?
Old Jul 11, 2006 | 02:53 PM
i think it has to be covered
Old Jul 11, 2006 | 04:37 PM
agallardo's Avatar
Thanks man appreciate it.
Old Jul 11, 2006 | 06:39 PM
agallardo's Avatar
Hey sorry to bother again. But I have one more question. Do I have to unplug anything off the intake at all? Like the little hose?
Old Jul 11, 2006 | 08:06 PM
agallardo's Avatar
Does anyone know if I have to unplug anything else? like the hose off the intake (the little one on the radiator side)???
Old Jul 11, 2006 | 08:40 PM
GrayGST's Avatar
hey i had the same problem i have a turbonetics mbc. to hook up mine you hook one hose to the wastegate itself and the other one on the tee fitting where the wastegate did. so in other words that little hose that went to the wastegate and the tee fitting in trash. you just plug your mbc between those two points no wires get un plugged or any other hoses. you should have the same set up but i dont think it matters. try this i almost positve it will work
Old Jul 11, 2006 | 09:44 PM
2nd g eclipse gst's Avatar
hey could it be that my boost gauge just suckz azzzzzzzz i got it off of ebay????
