boost gauge problem
ok here is an update. i noticed that the boost does drop in all gears but only when you reach high rpms. after you reach probably about 5000 the boost starts to drop. has anyone had this problem before and why does it only drop at higher rpms.
IMO, get your boost leak check out of the way. A boost leak may not present itself until higher pressures are introduced anyway.
Since you'll be in the area, check your turbo shaft for play and look at the wheel.
Just get the boost leak test done with, it's not that hard. Every turbo car owner NEEDS a boost leak tester and every turbo car owner should do BLTs as a preventitive maintenance type thing. That's just me though. I've already lent my BLT to MANY people who found leaks and didn't even know it.
and I use that term loosely) 1g BOV
