boost pressure
how much boost can a stock 1997 gst turbo hold. i want to up it when racing and run stock boost during street driving. also will i get more horsepower if i swap in a 1g turbo? i can get one for cheap.. what kind of boost can it hold?
RE: boost pressure
I just did it and I think its worth it.. Go check this out. https://mitsubishiforum.com/m_32969/tm.htm
The 14b is the stock turbo in the 1gens... |
RE: boost pressure
ORIGINAL: rico how much boost can a stock 1997 gst turbo hold. i want to up it when racing and run stock boost during street driving. also will i get more horsepower if i swap in a 1g turbo? i can get one for cheap.. what kind of boost can it hold? |
RE: boost pressure
thanks what size injectors should i go with on the 1g turbo if i boost to oh say 19psi? i have venoms now
RE: boost pressure
ORIGINAL: rico thanks what size injectors should i go with on the 1g turbo if i boost to oh say 19psi? i have venoms now |
RE: boost pressure
ORIGINAL: EMonz57 ORIGINAL: rico thanks what size injectors should i go with on the 1g turbo if i boost to oh say 19psi? i have venoms now |
RE: boost pressure
emonz gets a cookie!
RE: boost pressure
thanks i have 500 venoms now... i already have a 3000gt 190lph fuel pump will this be sufficient for high boost?
RE: boost pressure
ORIGINAL: rico thanks i have 500 venoms now... i already have a 3000gt 190lph fuel pump will this be sufficient for high boost? |
RE: boost pressure
if you plan on boosting it up that hi i would for sure get a tune.
Is the motor stock or do you have some mods?? |
