boost pressure
Old Nov 28, 2005 | 07:17 PM
rico's Avatar
Default boost pressure
how much boost can a stock 1997 gst turbo hold. i want to up it when racing and run stock boost during street driving. also will i get more horsepower if i swap in a 1g turbo? i can get one for cheap.. what kind of boost can it hold?
Old Nov 28, 2005 | 07:29 PM
TheAdvocate's Avatar
Default RE: boost pressure
I just did it and I think its worth it.. Go check this out. https://mitsubishiforum.com/m_32969/tm.htm
The 14b is the stock turbo in the 1gens...
Old Nov 28, 2005 | 07:36 PM
ORIGINAL: rico
stock T25 is only good till around 18PSI stock fuel is good till about 16-17PSI the 14B (stock 1G turbo) is good till about 19-20PSI but is more efficient and a better turbo than the T25.
Old Nov 28, 2005 | 07:46 PM
rico's Avatar
thanks what size injectors should i go with on the 1g turbo if i boost to oh say 19psi? i have venoms now
Old Nov 28, 2005 | 08:42 PM
ORIGINAL: rico
the EVOs can boost 22PSI on the stock 550s so I gues they are good, but dont forget a fuel pump too... and to have it run to its top potentcail adding fuel and and boost wont do getting a tune will work wonders with that stuff
Old Nov 28, 2005 | 11:57 PM
slow420a's Avatar
ORIGINAL: EMonz57
ORIGINAL: rico
I dont think it could have been said any better.
Old Nov 29, 2005 | 09:03 AM
emonz gets a cookie!
Old Nov 29, 2005 | 11:40 PM
rico's Avatar
thanks i have 500 venoms now... i already have a 3000gt 190lph fuel pump will this be sufficient for high boost?
Old Nov 30, 2005 | 12:07 AM
ORIGINAL: rico
190 is what I see alot of DSMs guys use for pumps
Old Nov 30, 2005 | 11:22 AM
Blue03Evo's Avatar
if you plan on boosting it up that hi i would for sure get a tune.
Is the motor stock or do you have some mods??
