bosst problem.(i think)
Old Sep 10, 2008 | 02:36 PM
needsagst98's Avatar
Default bosst problem.(i think)
i have a 98 eclipse gst 5spd and i just installed RRE piping. well at least the lower and the throttle body elbow piece. they screwed up the upper ic piece. so i have to send it back. but is like a 2psi drop over rpm range normal? like from 12psi to 10? and i havea turbo xs mbc with fine tune. if i try and tune it a little will it elimate that?. or is that always going to be like that?
Old Sep 10, 2008 | 05:09 PM
dsm1990gsx's Avatar
Default RE: bosst problem.(i think)
What rpm range does it drop off, my s16g will hit 16psi and slowly creep back down to 14/15psi.
Old Sep 10, 2008 | 07:45 PM
m i want to say about around 5k.
Old Sep 10, 2008 | 07:55 PM
If the turbo cant hold the flow then it will taper off, or if you have a boost leak it will taper off. Seeing how you just added IC pipes I going to jump out and say get a boost leak tester or make one and it should tell you where your problem is coming from
Old Sep 10, 2008 | 09:15 PM
ok thank you. im going to make one tomorrow morning and get everything ready to do it tomorrow afternoon. before i but the piping on i could hold 12psi no problem and no taper off at a certain rpm either.
Old Sep 10, 2008 | 09:37 PM
ok i just took it out and see what rpm exactly it was falling at. about 5900rpm is when it drops. if i put it in 5th and let it full spool to 12psi itll hold it. i held it for like 10-15sec and no drop what so ever. only at high rpm it seems to drop. and i know the max hp rpm is 6k from what i have heard. any ideas? sound like a boost leak? or something else? anything helps guys
Old Sep 10, 2008 | 10:54 PM
boost leak
Old Sep 11, 2008 | 06:40 AM
could just be the crappy stock BOV. I would start there because they always leak
Old Sep 11, 2008 | 07:25 AM
yeah thats why im thinking. i have to wait until tomorrow until upper pipe gets here so i can get everything together and then check the whole thing for leaks.
Old Sep 11, 2008 | 07:30 AM
ORIGINAL: TheEngineer
Which falls under boost leak, but if it wasnt leaky at 12 pIS before a LICP then it should leak at 12PSI after. Obviously if he was working on the charge pipes by taking them off and putting new ones on and now all of a sudden he is loose pressure Im going to have to go out on a limb and say he has a loose or bad connection slightly.
