Bov gasket boost leak
Old 03-02-2007 | 11:38 AM
burnmyeyes's Avatar
Default Bov gasket boost leak
Yesterday I found my boost leak. Its leaking at the bov gasket. The gasket seems to be in good shape, I tried tightening it down with different screws and nutsbut it did not help, so Im not sure what I have to do to stop the leak. What can be done?
Old 03-02-2007 | 11:42 AM
Default RE: Bov gasket boost leak
what type of bov is it. And i think if your using the stock flange then you can just get a new gasket to go there then screw it back on. How bad of shape is the gasket on the flange in?
Old 03-02-2007 | 12:23 PM
burnmyeyes's Avatar
The bov is a greddy type rs, and I'm using a aftermarket flange, not the stock. The gaskets are in good shape, they are still pretty new.
http://www.slowboyracing.com/more.php?id=2075&
pic of bov and gasket
Old 03-02-2007 | 12:34 PM
burnmyeyes's Avatar
Here is the flange I have
http://www.extremepsi.com/store/cust...357&page=1
Old 03-02-2007 | 12:45 PM
burnmyeyes's Avatar
A couple of ideas I had are maybe using two gaskets, or maybe putting onglue or something like that to create a seal? probably stupid ideas I know, but Im anxious to get this thing going again.
Old 03-02-2007 | 04:27 PM
estraw's Avatar
well for a last hope attempt, they make a gasket maker, kinda looks like a jb weld tube, you could prolly get it at any local hardware store, id get a new gasket first before i tried this tho
Old 03-02-2007 | 05:02 PM
burnmyeyes's Avatar
where can I buy a single gasket? I'm having a hard time finding one.
Old 03-02-2007 | 05:10 PM
burnmyeyes's Avatar
so far this is all I have found, would this work?
http://cgi.ebay.com/ebaymotors/Type-...QQcmdZViewItem
Old 03-03-2007 | 01:23 AM
paintballproam's Avatar
alright man this is easy, get some gasket material for like $5 and cut it to the shape you need, simple as that. or you could even use some RTV with the stock gasket or one you make yourself. simple
Old 03-03-2007 | 03:10 AM
I Drive Naked's Avatar
NEVER use 2 gaskets to try and solve the problem.
It'll leak worse and f **** up.
bad idea.
Get some gasket material and make you one.
Couldnt be morethan $5 at an auto parts store.
Quick Reply: Bov gasket boost leak
