Bov gasket boost leak
Old Mar 2, 2007 | 10:38 AM
burnmyeyes's Avatar
Default Bov gasket boost leak
Yesterday I found my boost leak. Its leaking at the bov gasket. The gasket seems to be in good shape, I tried tightening it down with different screws and nutsbut it did not help, so Im not sure what I have to do to stop the leak. What can be done?
Old Mar 2, 2007 | 10:42 AM
Default RE: Bov gasket boost leak
what type of bov is it. And i think if your using the stock flange then you can just get a new gasket to go there then screw it back on. How bad of shape is the gasket on the flange in?
Old Mar 2, 2007 | 11:23 AM
burnmyeyes's Avatar
The bov is a greddy type rs, and I'm using a aftermarket flange, not the stock. The gaskets are in good shape, they are still pretty new.
http://www.slowboyracing.com/more.php?id=2075&
pic of bov and gasket
Old Mar 2, 2007 | 11:34 AM
burnmyeyes's Avatar
Here is the flange I have
http://www.extremepsi.com/store/cust...357&page=1
Old Mar 2, 2007 | 11:45 AM
burnmyeyes's Avatar
A couple of ideas I had are maybe using two gaskets, or maybe putting onglue or something like that to create a seal? probably stupid ideas I know, but Im anxious to get this thing going again.
Old Mar 2, 2007 | 03:27 PM
estraw's Avatar
well for a last hope attempt, they make a gasket maker, kinda looks like a jb weld tube, you could prolly get it at any local hardware store, id get a new gasket first before i tried this tho
Old Mar 2, 2007 | 04:02 PM
burnmyeyes's Avatar
where can I buy a single gasket? I'm having a hard time finding one.
Old Mar 2, 2007 | 04:10 PM
burnmyeyes's Avatar
so far this is all I have found, would this work?
http://cgi.ebay.com/ebaymotors/Type-...QQcmdZViewItem
Old Mar 3, 2007 | 12:23 AM
paintballproam's Avatar
alright man this is easy, get some gasket material for like $5 and cut it to the shape you need, simple as that. or you could even use some RTV with the stock gasket or one you make yourself. simple
Old Mar 3, 2007 | 02:10 AM
I Drive Naked's Avatar
NEVER use 2 gaskets to try and solve the problem.
It'll leak worse and f **** up.
bad idea.
Get some gasket material and make you one.
Couldnt be morethan $5 at an auto parts store.
