Camber Kit
Old Nov 10, 2006 | 06:32 AM
mtalma's Avatar
Default Camber Kit
Hey Fellas,
I'm looking to straighten my suspension out after dropping my car. I was told my camber and caster is off. I'm planning on buying a camber kit from extremepsi.com. But they have different types like 1.5-2 and 2.0-3.0 I think this is how much correction it does on your camber, correct? Also, do I have to fix the caster of the tires as well?
What have people installed? I heard there was an easy way to get the camber corrected on the back tires. Anybody know?
Thanks.
Old Nov 10, 2006 | 07:05 AM
99madewell's Avatar
Default RE: Camber Kit
about four good thick washers will get you real close with a two inch drop. i bought an SRE rear camber kit anyways. worked really well for 60 bucks shipped. i still wanna get a kit for the front cause there is no camber adjustment on it from the factory. that sucks!! you'll be fine with the caster and toe because there is factory adjustment for that.
https://mitsubishiforum.com/m_96158/tm.htm
this is what i ended up with.
Old Nov 12, 2006 | 07:03 PM
mtalma's Avatar
I think I have found a good kit to correct my front and back camber from dropping the car. Check them out here http://www.diamondstarmotorsport.com...ionparts.shtml . Its the two last products on that page. What do you think?
Old Nov 12, 2006 | 07:12 PM
silvercoupe97's Avatar
ORIGINAL: mtalma
Good choice.
You will have full CAMBER adjustment front and back with those two. I would have an alignment shop check your negative camber by eyeballing it to get an estimate on how much of an adjustment you will need. If you don't need anything more than 1.5 degrees, for example, you won't want the one that goes up to 3 degrees
You can use the washers and longer bolts but, if you go this route, don't use the tiny washers. Thy don't provide a big enough surface area and will weaken the area that they sit on and eventually poke through. Those washers in that link are bigger than a quarter for referrence btw. Stay on the safe side and get the rear kit IMO, it has much more adjustability compared to just washers.
Oh yeah, CASTER is not adjustable, it is affected by CAMBER and TOE, but byitself, it is not adjustable in our cars. That is false.
Old Nov 12, 2006 | 07:40 PM
99madewell's Avatar
ORIGINAL: mtalma Oh yeah, CASTER is not adjustable, it is affected by CAMBER and TOE, but byitself, it is not adjustable in our cars. That is false.
maybe i should have worded that a little different. toe is and caster isnt. sorry.
Old Nov 12, 2006 | 07:58 PM
Oh ok, I gotcha.
DixonsGst
Jun 12, 2006 04:34 PM
bluballz07
Apr 1, 2006 08:28 PM
bluballz07
DixonsGst
Dec 11, 2005 04:42 AM
darkman0127
Oct 4, 2004 09:12 AM
