can u run a turbo with out a Compressor impeller ?
i have a jdm t3/t4 turbo so can you run a turbo with out a Compressor impeller but just dont ask why i would just saying.......
and i need help with my trans it works fine when i just cruise around but when i try to pass or get in it ,it trys to down shifts but it doesnt grab my engine just revs up untill i let off the gas. and i have a 4g63 with a auto trans,what can i do to stop this?:cool: |
first of all you already asked the thing about the turbo and i already told you the answer in your other thread. Would you please stop just opening up more and more threads. keep it all in one.
NO you cannot run a turbo without a compressor impeller. If you knew how a turbo actually worked you wouldnt even ask that. And it sounds like your torque converter on the trans is going. You will probably have to replace it. |
Have you checked the trans fluid? Does it smell burnt? What gears does it have problems w/?
You have me both confused and intrigued...why in someones right or left mind even fathom running a turbo without the compressor impeller?
try seeing if theres too much fluid in the trans or not enough... my trans slipped when i had too much in there when i didnt know what i was doing or u could try some lucas too
