can u run a turbo with out a Compressor impeller ?
Old Mar 19, 2010 | 10:30 PM
btlagunas's Avatar
Default can u run a turbo with out a Compressor impeller ?
i have a jdm t3/t4 turbo so can you run a turbo with out a Compressor impeller but just dont ask why i would just saying.......
and i need help with my trans it works fine when i just cruise around but when i try to pass or get in it ,it trys to down shifts but it doesnt grab my engine just revs up untill i let off the gas. and i have a 4g63 with a auto trans,what can i do to stop this?
Old Mar 20, 2010 | 11:23 AM
first of all you already asked the thing about the turbo and i already told you the answer in your other thread. Would you please stop just opening up more and more threads. keep it all in one.
NO you cannot run a turbo without a compressor impeller. If you knew how a turbo actually worked you wouldnt even ask that. And it sounds like your torque converter on the trans is going. You will probably have to replace it.
Old Mar 20, 2010 | 11:28 AM
dsm1990gsx's Avatar
Have you checked the trans fluid? Does it smell burnt? What gears does it have problems w/?
Old Mar 20, 2010 | 10:17 PM
3000gt16's Avatar
You have me both confused and intrigued...why in someones right or left mind even fathom running a turbo without the compressor impeller?
Old Apr 6, 2010 | 05:03 AM
DragonRacerX666's Avatar
Default ,,
try seeing if theres too much fluid in the trans or not enough... my trans slipped when i had too much in there when i didnt know what i was doing or u could try some lucas too
DSMSpyder615
Sep 30, 2011 10:00 PM
4g63blazer
Jan 7, 2009 03:53 AM
jerusry
Nov 22, 2007 08:18 PM
Sebba
21
Aug 2, 2006 06:19 PM
square1
Nov 21, 2005 12:30 AM
