Car is dying again! Help.
Old Jan 9, 2008 | 08:55 PM
dorian7's Avatar
Default Car is dying again! Help.
Ok so I just replaced the coolant temp sensor which fixed my check engine light problem but now I have a new one. I was driving down the road and all of a sudden when I put my clutch in the car would eaither die or die for a sec and then come back (I guess after it warmed up). It was really weird. I recently installed a Evo 3 16G but I drove 160 miles since then and didn't have this problem. All of a sudden it just came up. I checked the hoses for boost leak (since I took off the Upper IC hose to install the sensor) but it seemed tight and once the car starts back up it idles smooth and fine. It is weird. I noticed it I sit there and rev the engine the rpms shoot up and then when I let off the gas it sounds like there is a misfire or two. I don't know....
Old Jan 9, 2008 | 09:20 PM
bestwiseguy's Avatar
Default RE: Car is dying again! Help.
What bov are you using and are you venting or recirc.
Old Jan 9, 2008 | 09:25 PM
dorian7's Avatar
1g recerc. I had this problem before and it was a boost leak but when it was a boost leak it would only die when I made boost and put the clutch in. Now I don't even have too.
Old Jan 9, 2008 | 09:46 PM
dorian7's Avatar
Anyone?
Old Jan 9, 2008 | 10:41 PM
Boost leak possibly?
Old Jan 9, 2008 | 11:37 PM
dorian7's Avatar
well it's weird because it idles fine. And it only dies after it is warmed up (after the choke is off) I don't get it. Does anyone have ideas?
Old Jan 10, 2008 | 06:53 AM
I say leak as well. You can make a tester faily easy so you can actually verify you dont have a leak. Becuase sometimes its not obvious
Old Jan 10, 2008 | 10:04 AM
dorian7's Avatar
Ok I suppose that is what I will do today, thanks guys.
Old Jan 10, 2008 | 07:21 PM
dorian7's Avatar
OK I tested the boost leak. There was no noise other than the noise of what I think was just air running through one of the valves. (it sounded like a propane tank) I thought it might be the intake manifold to head. I put water with soap on it but there were no bubbles. I really need your help guys. It is weird. The more boost I make the easier the car dies. Like if I only rev it to 2k it is ok but past 3 it tried to die. I don't get it.
Old Jan 10, 2008 | 07:55 PM
jlh077464's Avatar
Does it feal like your hitting fuel cut?.....like does it feal like your losing all power, then when you let off the gas, does it come back to normal?
