Car/Shifter wont move?
try this... put it in gear, push the clutch and try to start it... make sure the E-Brake is on!! if it tries to jolt forward then stalls you might just need to adjust the clutch, or as estraw said, your slave cylinder( a black piece on bottom front of tranny that has a rod going into it) might be going out.. i recomend adjusting the clutch if it happens though... might help
I held down the clutch and started it but after thatit just sits in N. When I try to move the shifter to any gear it feels like something is moving in the way or something. Its like a wall in jumping out in front everytime I try to put it in a gear. Kinda weird when it was working fine yesterday.
