Car/Shifter wont move?
Old Nov 12, 2007 | 07:27 PM
USER_22's Avatar
Default Car/Shifter wont move?
Ok I can shift the stick around into any gearjust fine with the car off, butassoon as I turn the car on it refuses to shift into any gears, anyone know whats wrong?
Old Nov 12, 2007 | 07:29 PM
itsme71190's Avatar
Default RE: Car wont move?
wat kind of car?
Old Nov 12, 2007 | 07:31 PM
USER_22's Avatar
99 eclipse rs
Old Nov 12, 2007 | 08:10 PM
estraw's Avatar
slave and/or master cylinder is probably your culprit
Old Nov 12, 2007 | 08:17 PM
USER_22's Avatar
What, can you please put that is noob terms lol. I mean the car was work just fine yesterday, I came home and parked it and now it wont move.
Old Nov 12, 2007 | 09:31 PM
nick_200321's Avatar
try this... put it in gear, push the clutch and try to start it... make sure the E-Brake is on!! if it tries to jolt forward then stalls you might just need to adjust the clutch, or as estraw said, your slave cylinder( a black piece on bottom front of tranny that has a rod going into it) might be going out.. i recomend adjusting the clutch if it happens though... might help
Old Nov 12, 2007 | 09:52 PM
USER_22's Avatar
I held down the clutch and started it but after thatit just sits in N. When I try to move the shifter to any gear it feels like something is moving in the way or something. Its like a wall in jumping out in front everytime I try to put it in a gear. Kinda weird when it was working fine yesterday.
Old Nov 12, 2007 | 10:17 PM
well if it was working fine yesterday it is prob. the slave or master cylinder... im leaning on slave cylinder side... look it up and you will see a pic of it, they are like 20bux at advance auto
Old Nov 12, 2007 | 10:21 PM
USER_22's Avatar
K, kool ill check it out tomorrow and see whats going on. thx.
Old Nov 13, 2007 | 06:42 AM
Are you starting it in first or in nuetral. Cuz you want to try first and as soon as the car starts it will most likely stall on you
