center member
Old Jul 1, 2009 | 09:50 PM
wayne1's Avatar
Default center member
hell0,need some help with center member.
just wondering if they are the same in turbor cars as non turbo.
grand daughters eclipes 1995 is turbo ,we have access to non turbo
parts car. when she got the car hers was missing engine only being held in with rear rollstop and side mounts.rear roll stop bracket was broken
has been replaced.
thanks for any and all help
wayne1
hope this is posted correct.
Old Jul 3, 2009 | 06:43 PM
oh_what_up's Avatar
I don't have much experience with the non turbo eclipse's, but I'm 99% positive that they are different. The transmissions are on opposite sides of the engine bay not allowing it to match up for a direct swap. You may be able to find a used one for pretty cheap on ebay or dsmtrader though. Good luck! and i'm sorry i couldn't be of more help
Old Jul 3, 2009 | 08:39 PM
wayne1's Avatar
you were plenty helpful thanks for the reply.
will be ordering next day off,also doing the clutch.this will be learning
experiance.
did do a geo clutch wasn't to much of a problem.
tahnks again
wayne
Old Jul 3, 2009 | 08:40 PM
wayne1's Avatar
experiance.
thanks
Old Jul 5, 2009 | 10:37 AM
oh_what_up's Avatar
I'm glad I could be of some help. The clutch isn't too bad. Its just annoying getting the axles out. After that it should be pretty straight forward. Just remember to replace the clutch fork and pivot ball and check for proper clutch fork alignment after the transmission is remounted. (fork should be centered or a little towards the slave cylinder). Theres a good write up on www.vfaq.com
Old Jul 5, 2009 | 06:47 PM
wayne1's Avatar
thanks again
wayne
Unknown2U
Oct 17, 2005 09:09 PM
VENGE
Oct 9, 2005 05:02 AM
Flipz
Apr 29, 2005 03:37 PM
adornare
Feb 4, 2005 10:39 PM
pastorjay
Dec 18, 2004 06:51 PM
