check engine light code!
Old Jan 6, 2007 | 03:06 PM
bud660r's Avatar
Default check engine light code!
ok i did a serch and didnt find what i was looking for? so i did the key dance with my eclips and got 1-2-3-6-5-5, now how do i find out what this means!
Old Jan 6, 2007 | 03:59 PM
50ul }{4ck3r's Avatar
Default RE: check engine light code!
i look in my code book and dont see that code....the codes it have start with a P
Old Jan 6, 2007 | 04:52 PM
echostats's Avatar
You're doing something wrong. http://www.2gnt.com/nuke/modules.php...rticle&artid=8
Old Jan 6, 2007 | 04:53 PM
echostats's Avatar
replace the *** with 2gnt
echostats's Avatar
wow, this forum is ****ing gay. blocking all the other site words like d sm tun e r s and 2g n t
****ing get over it.
Old Jan 7, 2007 | 07:41 AM
silvercoupe97's Avatar
12 means power was removed within the last 50 start cycles, 36 means there was a shorted or open condition detectedin the secondary air injection solenoid circuit for the manuals, and 55 means "end of codes".
The Eclipse N/T has a Chrysler motor in it so it also allows for the keydance and those numbers come from that. The P codes are what you get when you plug in a scanner or logger. The P codes are better IMO, because it pinpoints the issue instead of just pointing out the area of the issue, lol.
Old Jan 8, 2007 | 09:34 AM
if you did a search then you didnt search good enough
https://mitsubishiforum.com/m_93759/tm.htm
Old Jan 8, 2007 | 03:57 PM
estraw's Avatar
ORIGINAL: echostats
You're doing something wrong. http://www.2gnt.com/nuke/modules.php...le&artid=8
if you click quote on this post of echostats, you can see the actual link
Old Jan 8, 2007 | 06:55 PM
...or just read post #6?
Old Nov 16, 2008 | 12:24 PM
Seashell2009's Avatar
So I forgot to check the oil in my 1996 eclipse and it started puttering when i came to a stop and i drove it for a couple of miles until i got home and my check engine light came on....and i was wondering if anybody knows how to find the code on it.....
please help......
