choosing the right turbo...
Old Jul 16, 2007 | 09:13 AM
RCJr9186's Avatar
Default RE: choosing the right turbo...
are you running stock turbo? you shouldn't be spooling that late... i'd check to see if you have a boost leak, check ur bov for a leak...
Old Jul 16, 2007 | 09:43 AM
jerusry's Avatar
mods, intake, SS headers, big 16g turbo ported and clipped, ported o2/dump pipe, downpipe, hi flow cat, 3 inch exhaust... left out some things.. but thats the idea....
Old Jul 16, 2007 | 09:46 AM
RCJr9186's Avatar
well the 16g does take longer to spool. a couple things you can do to get it spoolin quicker are
check ur spark plugs make sure ur gettin a good spark
wires (upgraded ngk, msd, wires are good)
new distributor if urs is stock/old... it helps
2.5" or even better - 3" o2 housing (makes a huge differnece!)
how big is ur down pipe? 3" is perfect
you don't START spooling until 3500 or you are done spooling at 3500? how much boost are you running? you may have a boost leak somewhere.. you can make a boost leak tester pretty cheap from lowe's.
Old Jul 16, 2007 | 06:28 PM
jerusry's Avatar
yeah, his turbo is not spooling right.. my 16g spools pretty early and is usually spooling at around 1800- 3300rpm.. at like 17psi...i headers, and ported o2 (its alot bigger then the factory one!!), and downpipe.. and ported turbo.... so it spools pretty quick. it allows me to have good lower rpm power, but it doesnt get much more on the top end...cuz it is a little turbo....
good luck fixin yer car.. cuz there is definitley something wrong with it...
Old Jul 16, 2007 | 07:38 PM
Nubiebubie_GSX's Avatar
Yah.. well my vacum reading at idle used to be 20 now its creeped up to steady 15 only at idle.. ill check it out.. but its not causing me any idle problem or hesitation.. just takes slightly longer lol. i just have a 3 inch cat back. k&N filter 1gen intake mani. That wut the car came with when i got it.
Old Jul 17, 2007 | 06:01 PM
jerusry's Avatar
nm
Old Jul 18, 2007 | 07:56 AM
RCJr9186's Avatar
boost controller?
Old Jul 18, 2007 | 09:16 AM
atown420's Avatar
i will definately check my bov for leaks and do a test i still havent since ive botten it but i need to. and its a big 16g and im running around 11-12 psi and have the 3" exhaust and downtube
Old Jul 18, 2007 | 09:26 AM
RCJr9186's Avatar
than you must have a boost controller to be running 11-12lbs... right?
Old Jul 18, 2007 | 09:41 AM
jerusry's Avatar
yeah man, you need an aftermarket boost conroller. and you need to check for the leaks in yer whole system buddy.
