RE: Clutch
try bleeding the clutch also check the master and slave and make sure there are no cracks or anything like that in it.
RE: Clutch
ORIGINAL: get435 try bleeding the clutch also check the master and slave and make sure there are no cracks or anything like that in it. |
RE: Clutch
you may just need to bleed the line better. There is a specific spot in the line that is very tricky to get the air out of. If the pedal sticks to the floor after shifting gears only during left hand turns, you need to worry about crankwalk. But if it does it during just normal driving or right turns too, its air in the lines.
RE: Clutch
ORIGINAL: eclipsed4u ORIGINAL: get435 try bleeding the clutch also check the master and slave and make sure there are no cracks or anything like that in it. |
