clutch adjustment
Old May 4, 2007 | 12:19 PM
brob13's Avatar
Default clutch adjustment
i just fixed a broken fluid line and now it grinds to get into first almost everytime. Im figuring the clutch needs a adjustment from being push all the way down several times when i was trying to fix the problem. Does anyone know how i can go about doing this? Or do you think its something else.
Old May 4, 2007 | 12:34 PM
Default RE: clutch adjustment
i believe we have a sticky on this, ill try and find it. But do a search cuz this has been discussed. Its basically a rod behind the clutch pedal. Did you properly bleed the lines?
Old May 4, 2007 | 01:45 PM
brob13's Avatar
yup i did all that but i think it was from trucker shifting it home but it only does it in first and there seems like there is alittle more play
Old May 4, 2007 | 02:36 PM
those are the only two things i can think of with what you worked on. I would think the lines not being bled would be the problem. Or not enough fluid. Im hoping its not a syncro. but i dont see how that would just happen. Its a possibility though
Old May 4, 2007 | 02:53 PM
brob13's Avatar
see but someone was saying that it was these pins in my shifters alignment or something i dont know but I think its because i was pushing the clutch all the way to the floor and it got un adjusted and now if i knew how i would just try to re adjust it because first gears is like the one that needs the most clutch isnt it and none of the other gears are grinding so i dont know
Old May 4, 2007 | 03:46 PM
i would just try adjusting the clutch pedal rod first and see if it fixes it
Jaygee61
Feb 1, 2008 10:25 PM
Wi_Fibre
Oct 18, 2007 10:36 AM
kleathers
May 11, 2007 07:59 PM
sodian
Oct 7, 2006 09:05 PM
Lefty
May 27, 2004 03:43 PM
