Clutch and Flywheel Advice?
Old May 9, 2006 | 02:12 PM
gstgurly22's Avatar
Default Clutch and Flywheel Advice?
ok... from tampa need to know a good clutch and flywheel brand.. no bull****.. i want a LIGHTTT flywheel and a good clutch that isnt goin to **** on me in 2 or 3 months!! For a 97 Mitsubishi Eclipse GS-T!!
Thanks, Sabrina
Old May 9, 2006 | 02:24 PM
Default RE: Clutch and Flywheel Advice?
ACT2100 Clutch and a Fidanza Flywhel. I have that combo on my Eclipse with 300hp and it bites hard. However, the stock flywheel bolts are a little short and you will need to get new longer ones. This is because the Fidanza flywheel is made from aluminum and because its not as strong it has to be thicker to compensate for it. So thats why. Many people just use the stock bolts anyway. I have never heard about any of them every comeing off but when i saw how far the bolts go in i was like... no way am i doing that. So i just got longer bolts.
Old May 12, 2006 | 04:16 PM
DSMTalonAWD51's Avatar
id agree except go for a 2600, no reason to get a 2100 they are the same price and the 2600 is not heavy
Old May 12, 2006 | 04:35 PM
You would only need the 2600 if you plan on doing decent mods and you want the extra bite. I dont think she has a heavily modded car so why the 2600? The 2100 is much easier to get used to.
Old May 12, 2006 | 09:16 PM
ORIGINAL: Sebba
what is this bite you are talking about? my 2600 is as light and as smooth to drive as a stock clutch. 2100's are the same price and they are weaker. sure you dont need a 2600 if you are only making mild power, but why get something worse when there isnt any downside or getting a 2600. if you ever make more power you will have a clutch that can support it. besides if you ever decide to go to a track, the 2100 is going to heat up just as bad as a stock clutch and take a dump on you
sk8dudety
Nov 12, 2007 10:37 AM
97spydergs
Oct 29, 2007 02:14 PM
EVO_CANEVO
Sep 28, 2007 06:29 PM
jerusry
Oct 14, 2006 12:35 PM
95HGeclipse
Mar 29, 2006 08:16 PM
