clutch pedal noise?
Old 04-21-2007, 09:31 PM
nyc95gst's Avatar
Default clutch pedal noise?
I have a slight squeling sound that seems to be related to my clutch pedal. It's not a very loud sound, but it is high pitched and annoying as hell. It seems to stop if I press on my clutch pedal a little bit, like deprerssing the pedal 1-2 inches.
Anyone ever have this problem?
95 GST
Thanks
Old 04-21-2007, 09:44 PM
Default RE: clutch pedal noise?
its your throw out bearing. Im almost positive thats your problem
Old 04-21-2007, 10:01 PM
silvercoupe97's Avatar
I second that. It doesn't mean that it's not anything else in the clutch system, but it's a good start.
..and yes, you'll have to remove the tranny to get to it and [:@]
Old 04-21-2007, 10:26 PM
yep, i'm sure that's what it is. the throwout bearing. i'm having the same noise come from mine right now, and that's what the problem is.
Old 04-22-2007, 01:10 AM
nyc95gst's Avatar
Thanks, that's what I read in the manual too, but I wanted to make sure. Damn. Aside from the stupid noise, what other porblems might I expect from this?
Thanks
Old 04-22-2007, 01:30 AM
well if the throw out bearing starts to get worse youll have a tough time shifting because you wont be able to dis-engage the clutch correctly
Old 04-22-2007, 01:36 AM
and i was told it's probably something you want to get fixed relatively soon, that way you don't run into those problems.
Old 04-22-2007, 10:21 PM
nyc95gst's Avatar
Yea, well if I am going to pull the tranny shouldn't I do more than just replace the bearing? Should I replace the clutch? Clutch release fork? Clutch slave cylinder? Clutch lines?
Old 04-22-2007, 10:22 PM
well if its been a while on the clutch i would just replace it since a clutch kit will come with a new TOB. Other than that you really dont need to replace anything else. Resurface the flywheel as well
Old 04-22-2007, 10:27 PM
nyc95gst's Avatar
Well I planned on upping my boost after replacing the motor mounts and from what I read, replacing the clutch makes sense with that in mind. I just bought the car so I am unsure how good or bad the clutch is.
Guess I need to start researching clutches. Damn. Seems like I am going to overhaul this motor. Lol
Quick Reply: clutch pedal noise?
