aftermarket speed controller
Would like to put a speed control on a 97 RS. Anyone installed an aftermarket? In looking at the RS, there are a lot of extra wires and connections. Did Mitsubishi use the same wiring harness for all types? That is, is the wiring for a factory speed control already in the RS?
RE: aftermarket speed controller
i'm also curious... the only reason i can think of is that you are a parent and this is your kid's car and you don't want him/her going over a certain speed but if this is not the case than i'm afraid i don't understand either.
There arent a lot of speed laws you are able to brak in a 420a lol.
The only thing i can think of... would be to put a bolt on the throttle body to stop it from opening all the way... man i would hate to be your child.
Well you are partly right. It is my son's car. No I did not mean speed control to keep the speed down, I ment one that keeps it at a set speed. Son is 6'4 and his leg gets cramped on his drive back and forth to college.
While we have been working on the car. I noted that there are a number of "extra" wiring connections. I am betting that Mitsubishi only used one wiring harness for all their cars. I have seen this in other vehicles. It would be nice to put in a factory cruise control, but the aftermarket units such as the Audiovox cc-150 appear to be workable. Just wondered if anyone had put one in.
BTW. If you want a great anti-theft or anti valet parking system all you have to do is hook up one of the auxiliary Tachometers that has a warning light on it. Take the light lead and wire it in so when it comes on the engine cuts out. Put a hidden switch in to turn the lead on and off and set the tach at a low rpm.
