Compression Test results
Old Aug 26, 2007 | 10:45 PM
racerx55's Avatar
Default RE: Compression Test results
usually a blown head gasket will leak more compression than that
i would honestly do a leakdown test , or just put constant air on that cylinder and see if you get air coming up out of the cooling system
Old Aug 26, 2007 | 10:52 PM
Or maybe it was tested incorrectly... but maybe is just barely leaking...
Old Aug 26, 2007 | 10:54 PM
racerx55's Avatar
#1 is always the first to have problems in them so to me lower compression would almost be normal, thats the first cylinder to lose rods bearings, and always has the most worn out rings and piston.
Old Aug 26, 2007 | 10:56 PM
Okay ... well the oil down the cylinder will tell you whats up
Old Aug 27, 2007 | 08:19 PM
Catch22!'s Avatar
160 to 180 is not all that bad. Normal range is 10 percent. You are just over that. Oil test would be my first, leak down would be my second. Actually, a repeat regular compression test would be my #1. Remember to open the throttle body to get the best results.
Old Aug 27, 2007 | 11:37 PM
Kaede.Noir's Avatar
just pour a damn cap of oil down the damned thing.... itll burn up anyways with no damage
angelogts09
Oct 20, 2012 03:17 PM
Bymp
Aug 1, 2010 05:10 PM
newguy2007
Mar 15, 2008 05:34 PM
ryant25bb
Oct 16, 2006 09:35 AM
ryant25bb
Oct 12, 2006 12:54 PM
