Compression Test Results?
Old Jul 30, 2010 | 02:32 PM
Bymp's Avatar
Default Compression Test Results?
From left to right my readings are:
(97 Mitsubishi Eclipse Spyder GST)
100
90
100
90
I'm fairly confused on these readings, I'm not sure how to determine if these readings are throwing up a red flag or not, I'll be honest to say I've never done a compression test before.
Can someone tell me what I should be looking for? What's an ideal reading?
Old Jul 30, 2010 | 04:43 PM
those numbers are way to low. Are you sure that you did the test correctly and that you had a good tight seal on the tester. Also you made sure to turn the motor over enough revolutions to get the max compression.
If you did everything right then you are well below the service limit (meaning that engine is really worn out). You may want to try a wet test. Add a little cap full of oil into the cylinder and retry the test. If the numbers improve then its the piston rings that are worn.
Old Jul 30, 2010 | 06:32 PM
Bymp's Avatar
I bought a new compression tester and ran it again, it was 170 on all of them, how does that sound? That's without a wet test and with the car warmed up.
Thanks for the help
Old Jul 31, 2010 | 08:35 PM
ah ha, yes much better. Nothing to worry about now.
Old Aug 1, 2010 | 05:10 PM
Bymp's Avatar
Great! Thanks a bunch
angelogts09
Oct 20, 2012 03:17 PM
newguy2007
Mar 15, 2008 05:34 PM
grim0reaper0
Aug 27, 2007 11:37 PM
ryant25bb
Oct 16, 2006 09:35 AM
ryant25bb
Oct 12, 2006 12:54 PM
