Convertible Top HELP!!!
Old Apr 16, 2009 | 06:32 PM
97Spyder2.0's Avatar
Exclamation Convertible Top HELP!!!
Hey I have a 1997 spyder and I need to fix the top the convertibles banged up. The front bar is bent. If anyone knows anything about convertible tops message me thanks!!
Old Apr 21, 2009 | 10:57 PM
2slow's Avatar
what do help you need to know i know a bit about them i own a spyder so i could probably
help you out.
Old Apr 23, 2009 | 06:31 PM
Hey 2slow
The problem is that the front bar is off the hinges were its supposed to be connected and its bent to ****. So I either need a new front bar and hinges. i have pictures if thats any help. I've talked with a few people about it and they dont make parts for them anymore. i've also looked around junkards but with no luck. I need this fixed before I put on a new black cloth roof and its holding me back from gettin it on the road. Any help would be great.
thanks man
Old Apr 27, 2009 | 11:18 AM
kevin784752's Avatar
The tops on these cars are known to have problems with the first bow. I have the same problem with my 98 spyder. The two pieces of metal that are bent in half need to be replaced wich i think you know. You can find them on ebay put in search year and covertible top you have to scroll through but there is a guy on there that sells them for 100 dollars. They are supposed to be much stronger then the factory ones and about a 40 minute install. Good luck
Old Apr 29, 2009 | 08:03 PM
Thanks Kevin
I just found them.
I think my bar is bent too... i'll probably have to replace that too. piece of **** lol
Thanks again
cheers
Old May 27, 2009 | 12:17 AM
flplaydoh's Avatar
I just got a 98 spyder but it has no back seat and all that the guy gave me with it is the rag top but I am obviously missing a few things because there is no folding arms of any sort... does anyone have a breakdown of what I need to make the top work or if they know where I could get the parts??? or even some pictures of your mechanical parts of your convertible.
I got a great deal on this car but I believe the guy got tired of not being able to find a way to get the top to work...
Old May 27, 2009 | 12:33 AM
eclpsegs1995's Avatar
www.car-part.com here ya go man good luck on finding what you need
Old May 27, 2009 | 11:42 PM
2slow's Avatar
okay the root of the problem is the elastic underwear material they used to draw the bar up when you put the top down i just removed the arms and assist my top its cheaper and no one but those who own a spyder know why
Old May 30, 2009 | 08:59 AM
profitwho007's Avatar
Default right
i agree with 2slow as i put my top down at the last sec you just have to asst the top a little i removed mine also.
Old May 30, 2009 | 01:20 PM
BrokeDad's Avatar
My top works great but does anyone know where to get the plastic cover that you can put over it when it's down ? The previous owner said it blew off and broke which he said is very common. It's not a necessity but the dealer wants $700 for it and I have gotten no responses from any junk yards even using car-parts.com. I even had a local junk dealer search for me and has yet to find one.
2001 Mitsubishi Spyder GS 2.4L
