WHICH COST MORE AN ENGINE REBUILT OR A USED
WHICH ONE WILL COST MORE ENGINE REBUILT OR GET A USED ENGINE INCLUDING PARTS AND LABOR?
RE: WHICH COST MORE AN ENGINE REBUILT OR A USED
All depends on what you want to do for the rebuild, if you are going to do it yourself etc. labor will always be the most expensive thingg
WELL BY THE SHOP DON'T KNOW HOW TO REBUILT AN ENGINE. SO WICH ONE IS LESS EXPENSIVE FOR THEM. TO REBUILD THE ENGINE OR SWAP A USED ONE PLUS PARTS AND LABOR
plz turn off your caps lock
What year and model is it? |
Its a 1997 gs 2.0L no turbo
Now why does it need a rebuild/new engine? what exactly went wrong?
i just bought it today and it has a loud knocking noise. the guy i bought from said it might be the main rod bearings.
hmmm if it was a 4g63t i would say crank walk. But im not sure. It could be a main bearing. but i would swap it, its cheaper and you know it will be ok.
ok thanks just trying to get the cheapest way. A swap then i'll shall do.
Its a 1997 gs 2.0L no turbo Replace it. |
