WHICH COST MORE AN ENGINE REBUILT OR A USED
Old Mar 3, 2007 | 12:19 AM
kikoavy's Avatar
Default WHICH COST MORE AN ENGINE REBUILT OR A USED
WHICH ONE WILL COST MORE ENGINE REBUILT OR GET A USED ENGINE INCLUDING PARTS AND LABOR?
Old Mar 3, 2007 | 12:20 AM
paintballproam's Avatar
Default RE: WHICH COST MORE AN ENGINE REBUILT OR A USED
All depends on what you want to do for the rebuild, if you are going to do it yourself etc. labor will always be the most expensive thingg
Old Mar 3, 2007 | 12:24 AM
kikoavy's Avatar
WELL BY THE SHOP DON'T KNOW HOW TO REBUILT AN ENGINE. SO WICH ONE IS LESS EXPENSIVE FOR THEM. TO REBUILD THE ENGINE OR SWAP A USED ONE PLUS PARTS AND LABOR
Old Mar 3, 2007 | 12:26 AM
plz turn off your caps lock
What year and model is it?
Old Mar 3, 2007 | 12:28 AM
kikoavy's Avatar
Its a 1997 gs 2.0L no turbo
Old Mar 3, 2007 | 12:33 AM
Now why does it need a rebuild/new engine? what exactly went wrong?
Old Mar 3, 2007 | 12:35 AM
kikoavy's Avatar
i just bought it today and it has a loud knocking noise. the guy i bought from said it might be the main rod bearings.
Old Mar 3, 2007 | 12:40 AM
hmmm if it was a 4g63t i would say crank walk. But im not sure. It could be a main bearing. but i would swap it, its cheaper and you know it will be ok.
Old Mar 3, 2007 | 12:43 AM
kikoavy's Avatar
ok thanks just trying to get the cheapest way. A swap then i'll shall do.
Old Mar 3, 2007 | 02:12 AM
I Drive Naked's Avatar
Its a 420A, nota 4g63.
Replace it.
