Crappy Design
If any of yall have a third gen eclipse, have you ever tried to get the center console to come up. You know to try to put in a neon switch. i cant get the front part that connects to the dash to come up its like its stuck
Any ideas? |
RE: Crappy Design
there are screw sort of up under it...near the fuel pedal
RE: Crappy Design
For the center console where the stick is? ok why not
RE: Crappy Design
quick question..do you mean where the red arrow is pointing, like the top of the console, or the yellow arrow, the entire console itself?
[IMG]local://upfiles/3223/2684103343B8443787BD7C381BC1CD71.jpg[/IMG] |
RE: Crappy Design
I mean both i think. Well since i don't really know what i mean how do i get both off.
or!!! if you know a better place to put a switch for neon that would not require me to drill a hole that would be even better. I know the fuse box is on the very left of the dash so would it be better to put the switch to the left of the stearing wheel? |
RE: Crappy Design
OH man i didnt see that pic enlarged untill after my last post.
But I see you have two switches where the ash tray is could you tell me how you got those there? |
RE: Crappy Design
you can put them in the coin holder thing....which is probably the crappiest feature that the car has
RE: Crappy Design
Ok so how do you do it?
RE: Crappy Design
my car came with an ashtray there, and i installed the switches...i ran a wire under the dash and down behind the radio...up to the ashtray area, and i used a ground around there as the other end of the switch. here is another picture
[IMG]local://upfiles/3223/BD47531E18934327B9C34EB3A27FCD88.jpg[/IMG] |
RE: Crappy Design
Then you just wire it to the fuse box.
if so do you need to buy a fuse to use, and which one would it be if i am using 2/20 in acc. Neons |
