Crappy Design
Old Aug 23, 2005 | 10:12 AM
newEclipse's Avatar
Default Crappy Design
If any of yall have a third gen eclipse, have you ever tried to get the center console to come up. You know to try to put in a neon switch. i cant get the front part that connects to the dash to come up its like its stuck
Any ideas?
Old Aug 23, 2005 | 12:05 PM
Patrick's Avatar
Administrator
Default RE: Crappy Design
there are screw sort of up under it...near the fuel pedal
Old Sep 1, 2005 | 09:08 AM
newEclipse's Avatar
For the center console where the stick is? ok why not
Old Sep 1, 2005 | 11:38 AM
Patrick's Avatar
Administrator
quick question..do you mean where the red arrow is pointing, like the top of the console, or the yellow arrow, the entire console itself?
[IMG]local://upfiles/3223/2684103343B8443787BD7C381BC1CD71.jpg[/IMG]
Old Sep 8, 2005 | 10:08 AM
newEclipse's Avatar
I mean both i think. Well since i don't really know what i mean how do i get both off.
or!!! if you know a better place to put a switch for neon that would not require me to drill a hole that would be even better.
I know the fuse box is on the very left of the dash so would it be better to put the switch to the left of the stearing wheel?
Old Sep 8, 2005 | 10:10 AM
newEclipse's Avatar
OH man i didnt see that pic enlarged untill after my last post.
But I see you have two switches where the ash tray is could you tell me how you got those there?
Old Sep 8, 2005 | 10:59 AM
eclipsed4u's Avatar
you can put them in the coin holder thing....which is probably the crappiest feature that the car has
Old Sep 11, 2005 | 03:05 PM
newEclipse's Avatar
Ok so how do you do it?
Old Sep 11, 2005 | 06:03 PM
Patrick's Avatar
Administrator
my car came with an ashtray there, and i installed the switches...i ran a wire under the dash and down behind the radio...up to the ashtray area, and i used a ground around there as the other end of the switch. here is another picture
[IMG]local://upfiles/3223/BD47531E18934327B9C34EB3A27FCD88.jpg[/IMG]
Old Sep 13, 2005 | 09:18 AM
newEclipse's Avatar
Then you just wire it to the fuse box.
if so do you need to buy a fuse to use, and which one would it be if i am using 2/20 in acc. Neons
klas
Dec 18, 2010 09:48 AM
WhiteTrash93
Dec 25, 2006 05:47 PM
GotBoost
Dec 12, 2006 08:57 PM
cucubana
May 1, 2005 01:36 PM
