Dim Headlights on upper beam ???
Old Feb 29, 2004 | 12:37 AM
Cliff  Todd's Avatar
Default Dim Headlights on upper beam ???
<FONT size=2>
I am having problems with the headlights on my daughters 2000 Eclipse </P>
The low beam is ok… However high beam causes the headlights to become very dim. Almost like it is shorting out. Probably getting about 1/3 of the power needed. </P>
I also had to replace the plugs that go to the headlamp bulbs. They had melted. </P>
I am thinking maybe somewhere along the wiring harness the wire to for the upperbeam got hot and melted into the ground wire </P>
Just wanted to see if any of you had a similar problem and if you did how did you repair. </P>
Thanks for your help! </P>
Cliff Todd </P>
</FONT><FONT size=2>crtodd@sydcom.net</FONT><FONT size=2> </P></FONT>
Old Mar 1, 2004 | 11:34 AM
BurntGSX's Avatar
I ran into this problem with my 97. my left head light would almost go OUT when I hit the brights. problem was... bad connection. the wire were just grounded so there would be a little light coming out. I took this to mitsu, DON"T DO THAT! they ran their little comp check s**t for an hour and said." I don't know" good waste of $84. go to a local guy that knows wiring, ended up costing me $184 total. (including the wasted hour of my life)
efatsi
Jan 28, 2013 01:48 PM
ruski
Nov 2, 2010 10:52 PM
vpleonard
Apr 27, 2004 08:47 PM
quicken
Mar 6, 2004 11:37 AM
2fast4u
Sep 6, 2003 06:44 PM
