disaster warning
Old Sep 25, 2006 | 11:46 AM
Mechwrench's Avatar
Default disaster warning
If you have what sounds like a belt squeeling, but no loose belts, check your harmonic balancer. Mine came loose from the rubber, cut into the timing cover and sent plastic through the timing belt. It didn't break the belt but it did slip enough to slam the pistons into the intake valves, bending every one of them. Luckily I was at a stop sign and the piston damage was minimal.
Old Sep 25, 2006 | 01:08 PM
Default RE: disaster warning
Ouch. Thats horrible. Thanks for the warning
Old Sep 25, 2006 | 01:49 PM
blamesociety's Avatar
no doubt. thanks for this. i will keep this in my head just in that case.
Old Sep 25, 2006 | 02:08 PM
agallardo's Avatar
Funny thing, that happened to me like 2 weeks ago. I knew it wasnt the belts. It sounded really bad. I took home, left it there till i got home the next weekend and i looked at it. It looked like the crankshaft pulley was loose, so I had my parents take it to a shop because i had no time to fix it, and it was the harmonic balancer. The sound got louder as the rpms went up. Luckily nothing bad happened to "my baby." Lol.
Old Sep 25, 2006 | 08:10 PM
Nubiebubie_GSX's Avatar
Should i be concerned also. I hear a little squeel when i start the car right after its been sitting over night and it rained. Only on rainny days it squeels .
Old Sep 25, 2006 | 08:22 PM
Thats ok... nothign wrong with that
Old Sep 26, 2006 | 07:40 PM
Mechwrench's Avatar
The squeal on start is all that mine did till the belt slipped. I think that they slip on start till the rubber heats up then it grabs. Its cheaper to check it then to do a top end or complete overhaul.
Old Sep 26, 2006 | 08:06 PM
But it only squeels for like a second and only when it rained and i dont drive it all day.. Still a concern or should i still get it checked..
Old Sep 27, 2006 | 02:33 AM
badass91hatch's Avatar
That would prob be rainwater gettin on your serpentine belt,mine does it also.Believe it or not rainwater can get on your belt
Old Sep 27, 2006 | 11:15 PM
Ohh.. well i dont have a lower cover for the belt.. its completly exposed..
