double piston brakes ??
RE: double piston brakes ??
the double piston refers to the caliper. where it has dual pistons to help for more of a solid stopping and to reduce uneven brake pad wearing by applying force to the whole brake pad. Ive heard that its much better for braking, but i think its more of a luxery than a neccessity, unless you have a really high performance car.
ORIGINAL: TheEngineer
EDIT: BTW, many newer cars will have dual piston front calipers stock- mine does, but has rear drums
ORIGINAL: romanrapido
where do the brembo brakes fall? double piston? 4 piston?
brembo brakes are nice but too much expensive. what other aftermarket brakes can i get to replace the stock ones?
ORIGINAL: 98eclpsrider
my bro put some race application break pads on his car and it stops way faster than when he had just the regular break pads on. but they squeek more when you're first wearing them in.
Thats why you can get brake lube that helps for that
