double piston brakes ??
Old Aug 23, 2006 | 07:34 AM
romanrapido's Avatar
Default double piston brakes ??
what are double piston brakes? are these types a good mod for a 97 gs-t?
Old Aug 23, 2006 | 09:15 AM
Default RE: double piston brakes ??
the double piston refers to the caliper. where it has dual pistons to help for more of a solid stopping and to reduce uneven brake pad wearing by applying force to the whole brake pad. Ive heard that its much better for braking, but i think its more of a luxery than a neccessity, unless you have a really high performance car.
Old Aug 23, 2006 | 05:18 PM
98eclpsrider's Avatar
there are also 4 pistons too. those are for big break kits and hard breaking applications two calipers on each side of the disc.
Old Aug 24, 2006 | 05:37 AM
where do the brembo brakes fall? double piston? 4 piston?
brembo brakes are nice but too much expensive. what other aftermarket brakes can i get to replace the stock ones?
Old Aug 24, 2006 | 09:21 AM
im not sure but if i had to guess i would say double
Old Aug 24, 2006 | 01:06 PM
dirtwagon's Avatar
ORIGINAL: TheEngineer
These along with larger rotors are also helpful if not a necessity if you plan on putting on larger wheels( like 20" plus) as it takes more brake force to slow the additional rotating mass- if I explained that right. Basically, if you are putting "Dubs" on a vehicle, you need to upgrade the brake system also.
EDIT: BTW, many newer cars will have dual piston front calipers stock- mine does, but has rear drums
Old Aug 24, 2006 | 01:25 PM
dirtwagon's Avatar
ORIGINAL: romanrapido
Brembo brakes will be a 4 piston caliper setup- typically the leading edge has a larger piston than the rest. You can also think about upgrading just your pads and rotors if the calipers are too much. You can check out Wilwood brake calipers at Wilwood.com, I'm not sure about a price comparison though.
Old Aug 24, 2006 | 02:21 PM
my bro put some race application break pads on his car and it stops way faster than when he had just the regular break pads on. but they squeek more when you're first wearing them in.
Old Aug 24, 2006 | 02:43 PM
ORIGINAL: 98eclpsrider
Thats why you can get brake lube that helps for that
Old Aug 24, 2006 | 04:58 PM
ya we put that on them, it just doing what all breaks do when you put new ones one squeek a little bit, it was like for a day of driving it around though nothing long or anything.
