dsm link
Old Aug 14, 2006 | 01:58 AM
thehintons06's Avatar
Default dsm link
can you tune your cars A/F ratio safely with a dsm link if you do not have a wideband?
Old Aug 14, 2006 | 08:46 AM
Default RE: dsm link
I doubt you can tune any A\F safley without a wideband. how will you know what your A\F is actually at without the wideband there to read it
Old Aug 14, 2006 | 04:22 PM
Well if you go to a shop to tune it they will just hook one up and do it then take it off when they are done. But its also a good indicator if you have a problem. Its worth getting one.
Old Aug 15, 2006 | 01:10 AM
Nubiebubie_GSX's Avatar
do not know if this is jacking or not but, do u need a 95 eclipse ecu to use DSMlink since it the programmable version. Or can any ecu year/model use dsmlink
Old Aug 15, 2006 | 09:41 AM
ORIGINAL: Nubiebubie_GSX
any year from 90-99 eclipse
Old Aug 15, 2006 | 07:56 PM
I was lied too [:@]. Somebody I met told me you need a 95 ecu to use dsm link and that is because its programmable.
Old Aug 15, 2006 | 11:27 PM
i would just go to the site and read up http://www.dsmlink.com/announce1g.html
Old Aug 16, 2006 | 02:20 AM
TX97GST's Avatar
Yes you do need a EPROM ECU and they only made those on 95 and older cars. 96-99 do not have EPROM and can not be used with the DSMLink. It says so on their site, so you were not lied to.
http://www.dsmlink.com/faq.html#requirements
Old Aug 16, 2006 | 12:50 PM
5Tizzle's Avatar
How does the Anti-lag work on dsmlink?
Also, what is it talking about in this part:
"OBD II fix2,3... Fixes the OBDII MIL bug in the '95 ECU. Mitsubishi did a recall on the '96 ECUs but offered no fix for the '95."
Old Aug 17, 2006 | 01:41 AM
Thank TX97gst that a costly thing but it might fix my missfire with the 6bolt swap with that inverted cas signal thing. But since i am poor and at a point where i would dance for money. It will have to wait.. Droppin 1200 into a whole new front end. Everything that has to do with steering.
BOOSTEDgirlGSX
Jan 25, 2007 05:23 AM
RCJr9186
Jan 9, 2007 04:23 PM
davidmitsusrock
Jan 8, 2007 04:45 PM
thehintons06
Sep 10, 2006 02:40 PM
thehintons06
Aug 24, 2006 05:51 AM
