eagle 4g engine??
Old Mar 5, 2007 | 02:14 PM
brknhrtdpimp1489's Avatar
Default eagle 4g engine??
ok so i was doing a little research and found that there are a few more cars that have the 4g63 engine than i previously thought...heres my question...i know that there are different types of the 4g engine like the evo has taller heads and what not...so would a 4g out of an eagle talon tsi fit a 97-99 eclipse gs-t?? any help is great...
Old Mar 5, 2007 | 02:35 PM
racerx55's Avatar
Default RE: eagle 4g engine??
Its the same car. will fit.
actually, evrything will fit.
if you completely strip an eclipse and a talon, you can swap evrything and pretty much intermix evrything and it'll all work.
BTW ONLY if theyre a GS-T / Tsi , or both non turbo
4g63 swap into a non turbo 420a car isnt worth the fabricating disaster it takes to do it.
Old Mar 5, 2007 | 03:07 PM
yeah thats what i was thinking but i just wanted to make sure...i know someone with a tsi and im looking for a gs-t shell so im just going to get him to let me have the engine out of the tsi and put it in the gs-t...but def thanx for the help...one more q though...would eclipse body kit for like 97-99 fit the eagle...mabe just do a body conversion instead of engine swap and what not...
Old Mar 5, 2007 | 05:47 PM
RCJr9186's Avatar
as far as i know the stock body from an eclipse will bolt up to a talon. but you will have to get a front facia, and rear fascia from an eclipse before you an get a kit for it or it won't fit.
Old Mar 5, 2007 | 05:50 PM
you might also need the headlights for the conversion. If you do a search on here i know it was talked about with the body conversion between the two
Old Mar 5, 2007 | 08:34 PM
sweet man i might just for now buy a talon and convert it over to the real sexiness that it wishes it was originally born to be...so i'll prob need headlight conversion which is kool with me b/c i like the headlights on the 2g eclipse way way better anywayz and i need the facias for the front and rear...ok so what about tail lights can i convert those too or am i just trying to do too much for what im gonna try and do...
Old Mar 5, 2007 | 08:46 PM
Ok i did the search and turned this up.
1. 95-96 Talons and Eclipses will need 97-99 Eclipse headlights to convert to a 97-99 Eclipse front
2. 95-96 Talons can swap directly to a 97-98 Talon bumper with no need for new headlights.
3. 97-98 Talons will need 97-99 Eclipse headlights to swap to a 97-99 Eclipse front.
4. 97-99 Eclipse will need 95-96 style lights to swap to any other 2g bumper
Hope it helps
Old Mar 5, 2007 | 08:50 PM
so i wonder if that means that number two up there means that those two cars had the same headlights...i think we'll all agree that the 2g eclipse had badass healight lol...oh and hey where did you search this at??
bsmooth99
Feb 22, 2005 02:22 PM
colinwolfe
Jun 12, 2004 04:31 AM
2fast4u
Sep 6, 2003 06:44 PM
shane82786
Jul 2, 2003 01:17 AM
