Eclipse 95 GS need help
Old Nov 28, 2006 | 10:31 PM
  #21
93eclipsegsx's Avatar
Default RE: Eclipse 95 GS need help
precat? as in a cat before a cat?
Old Nov 28, 2006 | 10:37 PM
  #22
Dookitchen's Avatar
So when I installed catback, The precat is removed? If it's remove is this bad if I need to go for emmission test?
So can that be the problem with my car?
Old Nov 28, 2006 | 10:43 PM
  #23
Sanguinius's Avatar
See this is where I fail on these cars. My car has a precat directly off the turbo then it goes to the cat then muffler. I'm not sure if the Eclipse kept this idea or not. If you installed a catback exhaust then it should START after the cat not before. A full exhaust startes at the turbo (Or exhaust manifold for N/A applications). The CEL being on for a secondary air reason MAY cause a failure in an emissions test. I'm not sure though in VA we don't have emissions just safety.
Old Nov 28, 2006 | 10:50 PM
  #24
Dookitchen's Avatar
What should I do to make CEL go bye bye? Emmission is coming in 3 months. I hate Baltimore. God damn emmission every 2 years. I bought my ECM from ebay and it works great and the guy told me to go to dealer while the ECM installed in the car to get it reset or reflash ( I forgot which one he said ) That is the time when the CEL came on. When I put used ECM in my baby.
Old Nov 28, 2006 | 10:56 PM
  #25
Dookitchen's Avatar
Somehow I have the feeling, it's my fuel pump because it feels like the fuel being push down when the car coming down from a bump.
Sorry for the double posting.
Old Nov 28, 2006 | 11:04 PM
  #26
Sanguinius's Avatar
Now I'm lost... How does the fuel feel like it's being pushed down?
And you can call a dealer about it but I doubt reflashing the ECU, ECM, whatever will help. The only time that is required is for security systems. There are some cars out there that the PCM, ECU, Key, and security all have the same code. If one code differs the car doesn't start. Obviously that's not the case here so reflash is unnecessary.
Old Nov 28, 2006 | 11:10 PM
  #27
Dookitchen's Avatar
Well like when you go on a bump really quick and come down from it... The car shakes bad and that's the time the fuel feels like not getting up from the tank to fuel pump
So what should I do to make that CEL go away? I wasn't clear what you were saying . SOrry
Old Nov 29, 2006 | 09:44 AM
  #28
first off do you know what code you are getting from the CEL. If not then thats the first thing to get. Go to autozone and they can read it for you. Then you can see what is wrong.
Old Nov 29, 2006 | 02:23 PM
  #29
shreff99's Avatar
Go get the vehicle scanned! That is where I would've started in the first place after checking the obvious grounds and such. If it has anything to do with any type of electrical sensor, wire, etc. then the scanner will spit the code out and you go from there instead of doing all of this guess work and wasting your time and money doing so.
Old Dec 3, 2006 | 06:55 PM
  #30
Dookitchen's Avatar
The car hasn't been doing bad since I clean the fuel injector.
Check Engine light throwing "Secondary Air Injection Malfunction"
I bought an o2 sensor simulator for...I hope it works.
thomas4g63
Nov 28, 2008 12:52 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
