ECU Replaced...now what?
Old Nov 5, 2006 | 08:02 PM
PooT_Nation's Avatar
Default ECU Replaced...now what?
OK, i finally got my ECU in the mail yesturday and I put in the New one today. I read on another forum that It takes a little bit for the car to reconize the new ECU. How long does it take? I took a 5 minute drive around the block, and it runs better than the old ECU, but still doesn't run like it should. Will it take a few drives around the block, a day of driving, ??
thanks!
Old Nov 5, 2006 | 08:34 PM
paintballproam's Avatar
Default RE: ECU Replaced...now what?
you should let it idle for 5-15 mins
Old Nov 5, 2006 | 08:38 PM
ok, i'll go let it idle
Ok reset the ECU and drive it around for a while. Dont go WOT for 15 mins.
Old Nov 5, 2006 | 09:00 PM
5Tizzle's Avatar
why did you get a new ECU?
Old Nov 5, 2006 | 09:02 PM
what's WOT?
wide open throttle, aka dont floor it
Old Nov 5, 2006 | 09:03 PM
how do you reset the ECU?
take off the negative battery terminal for a couple mins
Old Nov 5, 2006 | 09:05 PM
awww Brilliant. Ok, i'll let it idle for the 15 minutes and if that doesn't seem to work i'll reset the ECU
