EGR
Old Feb 21, 2008 | 10:54 PM
98gstspy's Avatar
Default EGR
ok guys, still working on my eclipse gst. we replace the head gasket now the car wont run right. timing is dead on. while doing some reading i found that an egr valve could be causing my car to shut down. heres what happens the longer the car runs the less likely it shuts off. when it starts cold it goes to 2700 rpm then to 1000,then sputters to 100ish then starts all over again,back to 2000ish and eventually it diesbut as i let it warm up and do it it will bounce back up to about 900 rpm witch is normal. could this b a faulty egr valve giving me 4 months of pain?
Old Feb 21, 2008 | 11:10 PM
estraw's Avatar
Default RE: EGR
possibly. if your egr valves going bad it can cause all kinds of weird stuff to happen. i broke mine last year and i had to tape it till i got a new one lol. it wouldnt let my car run at all even if i gave it gas. it would just stall
Old Feb 21, 2008 | 11:15 PM
98gstspy's Avatar
Default RE: EGR
i kinda sound like that, it wants to run but it shuts off after about 3 cycles of what i explaned earlyier
Old Feb 22, 2008 | 01:25 PM
dorian7's Avatar
Default RE: EGR
I didn't think our cars had an EGR valve... I thought only the 420a had it.
Old Feb 22, 2008 | 02:37 PM
Default RE: EGR
Hell yes they do
Old Feb 22, 2008 | 03:41 PM
Sheijin's Avatar
Default RE: EGR
Really? My eclipse was doing that too. Could that be the EGR then? It sounds exactly the same.
The motor came out of a galant vr-4 and it's the 6 bolt.
Old Feb 22, 2008 | 06:16 PM
98gstspy's Avatar
Default RE: EGR
ok now i gotz it all together now i have to give it a little gas to start. im going to autozone to test it inb a little bit. we will c what happens
Old Feb 23, 2008 | 11:24 AM
98gstspy's Avatar
Default RE: EGR
ok its not the egr. my valve was dirty but still worked. checked the solonoid to. both are fine. could it b my isc
i mean idle air control valve?
or is there another sensor that could cause this?
Old Feb 24, 2008 | 06:55 AM
tjbiker031's Avatar
Default RE: EGR
mine did something simularto what your car is doing. i thought it was the ISC but in the end i had to mess with my BISS....you might want to try messing with that, just make sure you count the turns if it doesnt help so you can put it back to how it was
Old Feb 24, 2008 | 08:45 AM
dsm1990gsx's Avatar
Default RE: EGR
I had a bad isc on my 1gen after I changed the timing belt and would let me start the car and stall within seconds. I replaced it and it was fine.
