Electrical source
Posted this on the electrical site, but wanted to see if the 2G group might have a more specific answer. Previous owner added a lot of neon lights and other electrical items. He took his power by wrapping the wire to the side of a fuse. I would like to add in another fuse block, but want to have it so when the key is off the power is off. How are others wiring in add on electrical items ?
ORIGINAL: sk8dudety
well if you wanna run it off another fuse, then with the car off take an electrical test light and find a fuse that doesnt have any power to it, and splice it off that
or even the cig lighter, because thats never on unless the key is in
well if you wired it to the lights, you'd be limited as to when you'd be able to use it, cause no ones gonna there lights on in the middle of the day for that.... just find a fuse that turns on when the key is on, and off when the key is off, and wire it into there
