engine break in/transmission life
Old Mar 20, 2009 | 07:57 AM
oh_what_up's Avatar
Default engine break in/transmission life
I know that procedure for breaking in the engine, but what type of oil should I use for the first 500 miles? I was reading somewhere that you should use non synthetic.
Also, how long do you guys think my transmission will last with this new set-up (4g63/64 hybrid) on 25-30psi. I have a few track days coming up and i'd like to be able to drive my car home afterwards with all the gears intact.
Thanks guys
Old Mar 20, 2009 | 07:59 AM
oh_what_up's Avatar
this is under the assumption that the engine is tuned. So, eliminating that I'm only worried about the drivetrain: transmission, axles, transfer case, rear diff. Since I haven't done anything to upgrade those
Old Mar 20, 2009 | 08:15 AM
Yes you ONLY use cheap non-synthetic oil for the breakin period.
And your drivetrain should be fine as long as your not totally beating on it, as in Dumping the clutch and trying to hardshift gears.
Old Mar 20, 2009 | 01:02 PM
Read this:
http://www.mototuneusa.com/break_in_secrets.htm
I have stood by this method for years now, and it hasn't gone wrong for anyone I know.
n0c7
Oct 29, 2007 08:32 PM
rick hunter
Feb 16, 2007 02:23 PM
galant2001
Jan 1, 2007 11:04 PM
scionlife
Oct 30, 2004 12:36 AM
GSXual
Aug 30, 2004 07:09 PM
