engine componet locations.
Old Feb 20, 2005 | 07:07 PM
ecp_drv's Avatar
Default engine componet locations.
I just had my engine check light came up. I did a test and got the diagnostic codes. But I cant figure out where they pieces are located so I can fix it.
They are:
Airflow Sensor, Idle Air Control (IAC), and Traction Control (TC) vent valve solenoid.
where are they located? Please help
Old Feb 20, 2005 | 09:40 PM
customizedrides's Avatar
Default RE: engine componet locations.
Your air flow sensor is usually right after the throttle plate. There should be a throttle position sensor and then the air flow. There might be a diagram on the hood, just look for the Mass Airflow Sensor. Traction control I would think would be around the tires like an ABS sensor but that's just a guess. Idle air control should be somewhere not far off from the intake. You can also pick up a Haynes manual for it and those are great.
aznboi_2
May 17, 2009 02:14 PM
lNoval
Jan 26, 2009 04:17 PM
itsmaheshp
Dec 3, 2007 06:49 AM
Dragonslayer
May 10, 2007 09:37 PM
wicked_outlander
Apr 22, 2005 06:18 PM
