Engine Fans
Old Jan 27, 2007 | 04:24 AM
50ul }{4ck3r's Avatar
Default Engine Fans
i was wondering if there is a way to make my two fans under my hood turn on when i start my car...cause it gets mighty hot in there
Old Jan 27, 2007 | 04:26 AM
Default RE: Engine Fans
Yes you turn on your A/C and press the little button
Old Jan 27, 2007 | 04:35 AM
what button
Old Jan 27, 2007 | 04:44 AM
The A/C button ....The one with the little star/snowflake on it LOL
Old Jan 27, 2007 | 05:45 AM
silvercoupe97's Avatar
..or you can just wire them straight to a toggle switch and the battery with a relay tied into the ignition (so that they turn off after you turn off the car).
Is it overheating? Or are you just having cooling issues because of the large IC?
Old Jan 27, 2007 | 07:38 AM
5Tizzle's Avatar
you can get a lower temp thermostat that opens at 180 degrees instead of 192. Are your fans just not turning on, or is it just getting hot for no apparent reason?
Old Jan 27, 2007 | 03:03 PM
i never hear them turn on.....over my engine.....but i have no clue if they turn on or not....the engine gets hot and stays hot
Old Jan 27, 2007 | 03:16 PM
you will always tell.. because the car will stutter for a split second and it will most likely be when you are standing in traffic.
Old Jan 27, 2007 | 04:12 PM
i dont know...i think im gonna go and drive it alil and leave my car running and check under the hood...to see if they are on...don't know but
Old Jan 27, 2007 | 05:36 PM
racerx55's Avatar
Have you checked the coolant level yet?
