Engine lean=hard starting up?
Old Jan 29, 2008 | 01:17 PM
asphalt_pimp's Avatar
Default Engine lean=hard starting up?
Well I have a hard time to get the car to start anytime, and I was wondering if this problem could be caused by it being to lean. Why would the car be lean anyway if I replaced the O2 censor and all the plugs-n-wires? Fuel injectors are clean, plus a new fuel filter and pump. I think it could be a leak or the EGR valve is bad but I can't tell. So I need to know if their is another sensor is bad or what the hell is going to happen if I don't fix the P.O.S.
Old Jan 29, 2008 | 01:23 PM
Default RE: Engine lean=hard starting up?
what year/model is the car and do you have any check engine light. Also how do you know its lean anyway
Old Jan 29, 2008 | 09:37 PM
RCJr9186's Avatar
the infor that TheEngineer is what i need to know as well butA solution is an SAFCII and just add a lil fuel.
gbrown
Jan 14, 2010 03:50 AM
ilb2fast4u
Nov 1, 2008 07:07 PM
asphalt_pimp
Oct 17, 2007 10:15 AM
hosrom
Mar 31, 2007 08:28 PM
a2rht930
Apr 10, 2006 01:13 AM
