engine removal
Old Jul 17, 2007 | 04:00 PM
Dusty Eclipse's Avatar
Default RE: engine removal
lol, CRANKWALK! j/k
Old Jul 17, 2007 | 04:17 PM
jah61's Avatar
ok what do mean by crankwalk?
Old Jul 17, 2007 | 06:57 PM
jrconnn's Avatar
Your engine can come out through the top . You'll have to remove the hood .You should check your oil pressure.
Old Jul 18, 2007 | 10:44 AM
atown420's Avatar
what is normal pressure for a gst? or average.
Old Jul 18, 2007 | 02:07 PM
Natedogg89's Avatar
ORIGINAL: jah61
look what you started now Dusty, lol. Do a search jah61, there are tons of threads about it, just search "crankwalk"
Old Jul 18, 2007 | 05:17 PM
jrconnn's Avatar
My experience has been around 25psi at idle and 40psi driving.
Old Jul 18, 2007 | 05:40 PM
TheAdvocate's Avatar
It would help if you told us what your running for a setup and what kind of eclipse/year..
I just pulled my motor out last night and we pulled it out from the top. The easiest is pulling the tranny out with it..
Old Jul 18, 2007 | 06:32 PM
atown420's Avatar
i have a 97 gst with big 16g turbo mbc intake 3" exhaust thats about all
Old Jul 19, 2007 | 12:58 PM
jah61's Avatar
ok I researched crankwalk on then web it sound like the motors are turbocharged and 2g engine with manuel trans. I have a 99 eclipse with a stock 420a engine non turbo auto trans. Is there any crankwalk problems for that engine? I suspect the kid that this car I bought it from ran it with out oil or it has a blown headgasket.
Old Jul 19, 2007 | 01:05 PM
RCJr9186's Avatar
no it shouldn't be crankwalk.... i've never heard of a crankwalk case in a 420a but theoretically it is possible for it to happen. OK. atown tried to jack your thread instead of opening his own [:@]so you are running a stock 420a right? it's most likely a spun bearing. these cars have weak bearings from the factory. if its coming from the bottom of the engine i'd bet my left big toe it's a spun bearing.
OH and 99.9% of 420a's will blow their had gaaskets at some point b/c of the facotry not tightening down the stockhead boltsin the corners. I owned mine for 2 1/2 years and mine blew on about 110k miles.
mlahrens
Jan 29, 2016 06:54 AM
98gs420a
May 13, 2010 06:58 PM
Clipsn
Mar 27, 2008 09:07 AM
tdf
Apr 19, 2007 01:47 AM
BlackMurcielago
Dec 10, 2006 09:21 AM
