| evrchanging-ecl |
Jul 13, 2014 11:58 PM |
Engine shuts off after 20 miles
It is a ’97 Mitsubishi eclipse GS. I recently had a manual transmission put in it but the Engine Speed Sensor in the transmission is not hooked up to the computer. Anyway, the car drives fine for about 15-20 miles. The temperature gauge gets to just under halfway, where it’s supposed to be. Then after about 10 minutes the engine shuts off and the rpms drop. If I keep the gas pedal down it sputters and tries to accelerate but to no avail. If I take my foot off the gas the engine dies and stays dead. As soon as it dies the first time I push in the clutch and it idles/coasts just fine. I pull over and turn the car off for a few minutes then it turns on just fine. I drive for another few miles and it turns off again. If I keep the rpms low I can go farther than if I don’t. The strange thing is that the temperature gauge never goes above half.
I have already replaced the spark plugs and the ECU and the same problem occurs. I have heard that it might be a stuck thermometer, or a problem in the ignition system. Does anyone have any ideas on what might be causing this and how to go about fixing it?
