Engine tapping
I have a eclipse rs and i took it to a machine shop and they repalced 3 valves. They checked all the rest and said they were fine. So we put it back together and it still makes a tapping noise from the top end at the number 1 or 2 cyclinder. We used a stethoscope to determine this. Anyon have any ideas what could be wrong? we left the lash adjustments in the head when we took it in to the shop. Could that be why it is tapping. Do we need to reprime them with oil? Or does it sound like a valve. The engine idles just fine but the tapping moves around. any ideas?
If it's a "come and go" type of ticking where it dissappears and comes back- it's more than likely your hydraulic lash adjusters (lifters). There really no need to prime them as oil pressure will surely pump through them right away while cranking. Is there any particular reason why you had to replace 3 valves? If they were burnt- perhaps you had a problem with the lash adjusters in the 1st place causing them to burn out??
Joel, CA
Joel, CA
it is a tapping noise comming from the top end. I talked to a dealer mechanic and he said that if you dont prime the lash adjusters then it will do this. so we are just going to replace them since im going to have to take the head off. AGAIN. this sucks.
