-   -   engine trouble (https://mitsubishiforum.com/forum/2nd-generation-63/engine-trouble-26435/)
laurenk Mar 21, 2008 10:52 PM
engine trouble
hey guys.. i don't know a whole lot about how engines work so im sorry if i sound like an idiot, but in one of my eclipses (1997 rs) i had a blown motor and just put a replacement in. the 'junkyard' type place i bought it from said it ran when it was pulled, and it turned over fine outside of the car. but, once we got it in there, the engine wouldnt even backfire or give a spark or anything. when we first tried starting the engine it caught for a second but then after that we didnt have any luck. any suggestions?
tuckGST Mar 21, 2008 10:58 PM
RE: engine trouble
Be sure that your timing is set.
tjbiker031 Mar 22, 2008 08:03 AM
RE: engine trouble
check timing, check for spark, check fuel.
98gstspy Mar 23, 2008 02:07 PM
RE: engine trouble
yea what they said timing is a pain if it isnt set up correctly.
TheAdvocate Mar 23, 2008 03:24 PM
RE: engine trouble
Make sure your spark plug wires are on the right cylinders..
Sebba Mar 23, 2008 08:47 PM
RE: engine trouble
Could be a crank angle sensor, or perhaps an ignition control module. Very hard to tell without testing equipment.
