Faulty speedometer?
Old May 30, 2008 | 08:13 PM
kennyinla's Avatar
Default Faulty speedometer?
Hey guys,
This may be a very n00b question but my speedometer is jacked up. Whenever I drive it bounces up and down. It doesn't go below the actual speed i'm traveling. But it does got past it. For example, If i am driving at 40 mph it will shoot up to 80 then come down. Then it will go up to 60 and come down.
The second problem is the tripmeter(i think that is what its called). It's not displaying the correct information. Its telling me that I get 385 miles per tank....I wish that was true. XD
btw i'm driving a 96 Spyder gs (non-turbo)
Old Jun 1, 2008 | 06:27 PM
darknigh7th's Avatar
Default RE: Faulty speedometer?
you might need a new gauge set, not sure where to get those, the might be a bad speed sensor as well, not too sure so don't quote me on that.
Old Jun 1, 2008 | 06:34 PM
My bet is on the speed sensor. If the gauge is showing anything at all its unlikely that its bad. If its erratic, then my bet is the sensor.
Old Jun 2, 2008 | 12:59 AM
kennyinla's Avatar
speed sensor, aye....i'll check it out...
thanks guys
Old Jun 2, 2008 | 02:33 AM
silvercoupe97's Avatar
ORIGINAL: Sebba
That would be my thoughts too.
Old Jun 6, 2008 | 12:38 AM
kennyinla's Avatar
So it turns out my rear motor mount needed to be replaced. The vibrations of the engine screwed up my speed sensor...
replaced motor mount and adjusted speed sensor...now everything is working fine...XD
Old Jun 6, 2008 | 03:29 AM
drifter28's Avatar
I think there's a kink, or tight bend in the drive cable, and it's about to break or it could be your nylon cog that connects to gear box drive. Just an idea.[sm=hiya.gif]
Old Jun 6, 2008 | 07:05 AM
woohoo i actually gave advice that was correct!!
Old Jun 6, 2008 | 09:16 AM
kennyinla's Avatar
if it happens again i'll replace it.
Old Jun 6, 2008 | 11:51 AM
I am a ****ing genius
roach
Feb 8, 2023 11:10 AM
klas
May 16, 2009 04:24 PM
rapperbasher
Aug 10, 2007 12:28 PM
pauljdodson
Aug 7, 2005 02:17 PM
Frost
Mar 6, 2005 04:28 PM
