fixed my idle
Old Mar 3, 2008 | 08:26 AM
oh_what_up's Avatar
Default fixed my idle
I got really tired of my idle surging so I bought everything i could think of to fix it. I replaced the TB seals, put in a fiav block off plate (kept the IAC-they make a special plate for it), new biss screw, o-ring, and rubber cap, TB gaskets, aeromotive AFPR and adjusted the TPS. Now it idles perfectly at 800rpm. Just thought I would share for anyone that was having the same problems. If anyone needs any help or suggestions let me know. Have a good one guys.
Old Mar 3, 2008 | 09:46 AM
dsm1990gsx's Avatar
Default RE: fixed my idle
So much for daignosing your problem lol, well at least your fixed it.
Old Mar 3, 2008 | 11:53 AM
bagaak's Avatar
how long did all that take you?
Old Mar 3, 2008 | 11:56 AM
Congrats : )
Old Mar 3, 2008 | 10:29 PM
98gstspy's Avatar
what was your idle doing b4 all this work cause i have a problem with mine right now. i start it up and it will die if i dont rev it once, but after that one rev its all good . you got any ideas. i was thinking of changing my tps and my ics? not sure what the problem is though.
Old Mar 3, 2008 | 11:06 PM
sk8dudety's Avatar
haha that's sweet man, congrats
Old Mar 4, 2008 | 06:09 AM
oh_what_up's Avatar
It only took me about an hour once all the parts arrived. 98gstspy, my idle was really high when i first started my vehicle. I could screw the biss screw all the way in and it still wouldn't drop down. Every so often it would also surge from 1500-3000rpms. Then after it was warm it would idle really low and sometimes die like yours. I would say make sure the tps is set correctly, or if it is old, replace it. Its easier to adjust if you have a data logger or if you watch the voltage on the safc. I hope that helps brother. Thanks guys
Old Mar 4, 2008 | 10:47 PM
98gstspy's Avatar
well i know that my tps is old so you think i should replace it then. i was also looking into the ics you think that could b it to?
Old Mar 6, 2008 | 07:05 PM
oh_what_up's Avatar
I would definately replace the tps, but as far as The IAC i would wait and make sure there are no leaks first. If you have leaks in the throttle body the IAC won't be able to compensate for them after a certain point. If fixing the leaks and the tps doesn't fix the problem, then start testing the IAC.
Old Mar 6, 2008 | 10:45 PM
98gstspy's Avatar
ok well i gotz to wait until i get paid b4 i can get a new tps. ill keep you up dated. but you say you think its the prob. so i will trust you.
